Transfer Case Drop Kit
Discussion in 'The Garage' started by caleb22, Mar 18, 2006.
  1. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
    Anyone know of a transfer case drop kit for a 89 K5? I came across one that BDS makes but I can't find anyone who sells it.
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    you can just take the spacers that are on the top inside the frame and move them to the bottom.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I don't see why you need a "kit". Just use the factory spacers (like he said) or find a couple pieces of square stock and drill two holes in each.
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Heres a picture of the factory spacers just moved around to the other side. If your going to do hard wheeling the best setup is to get a 1" square bar and drill hols in it. Most just move the factory spacers.
  5. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    I used 1x2 square tubing about 6 years ago and they are still going strong.
  6. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    Did you guys experience any tranny or t-case leakage due to the drop?
  7. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    be aware that putting the factory spacers like shown in the pic can tweak the bottoms of the frame rails... atleast it happened on mine.
  8. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    you can use the factory spacers which i did at first , but i got alot of popping which meant i needed something betta. so i cut some 1x1 squares that were 1/4" thick and used them. been working great and no more popping. :D
  9. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Its so clean, and new exhaust?
  10. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    purpose of spacers...
    The purpose of the origional factory spacers is to increase the bolt grip, not as a means to drop the t-case. Yes, it does work, and I've tried it too, but it bent the crap out of my frame. A solid block of steel is a better choice for a spacer.
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I have a ORD drop kit that I never used if you want to buy it. 50.00 shipped.
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    You got me curious, increase the bolt grip?
  13. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    x2.
  14. 88Silverado
    Mar 13, 2003
    2,664
    I keep all my vehicles drivetrain clean. I do wheel the Blazer but when I return I steam clean it to look for cracks and leaks. I Hate working on greasy vehicles in my old age.
    The crossover pipe is new since I had to do some exhaust work and got tired of the front shaft hitting it so had a slightly modified one installed. Still waiting to crush it on a rock but it hasnt happened yet.
    As I said the factory spacers can be used to perform the drop but the best way is to use a block type material, as mentioned in this thread, to distribute the load to prevent tweaking or cracking of the frame rail.
    Mine has a slight leak from the rear case seal but thats not due to the t-case being dropped, its due to a bad seal. In fact the seal from the trans to the case is also bad so every couple of oil changes I remove the t-case fill plug, drain out the excess, then top of the transmission fluid (flow-thru design :)). The best way to set this up is with a high-angle driveshaft but I dont have the money for that. I do have replacement blocks drilled just havent installed them yet.
    I was really suggesting the poster should try dropping the case to see if that gets rid of the vibe problem. So he can either try the factory spacers, a drop kit, some blocks or say screw it and get a new driveshaft.
  15. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    So you guys advocating the blocks instead of flipping the spacers, you talking about using the blocks and spacers or just blocks with no spacers?
    Not trying to hijack, just had a similar question.
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Same sound reasoning as swapping to more durable axles, HD:D
  17. 88Silverado
    Mar 13, 2003
    2,664
    Order of preference:
    1) High angle driveshaft
    2) Blocks to shim down t-case
    3) Use factory spacers to shim down t-case
    Use either blocks or spacers but do not use both together.
  18. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I used the factory spacers at first. I caught my crossmember last summer and tweaked my frame. After that I picked up some 1" by 2" tubing. I cut and drilled it for my t-case drop now and haven't had any more problems. :D
    Rick
  19. sarasotausmc
    Dec 16, 2003
    769
    Jacksonville NC
    gotcha, thanks 88silverado
  20. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    Bolt grip is the length of bolt between the nut and bolt head. If the grip length is too short it cannot be properly preloaded and will have a tendency to loosen; Think of the bolt as a spring with a high stiffness. The spacers basically insure that the spring is long enough for the given diameter. As a general rule of thumb, the grip length should be at least 2.5x the bolt diameter. Make any sence? :doah:
