Transfer case drop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coreyd, Jul 21, 2004.
  1. coreyd
    coreyd Registered Member
    Mar 24, 2004
    76
    San Mateo, CA... from South Dakota
    Has anyone installed a transfer case drop, and if so what ddid you gain by doing this.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I installed one on my 84 K5 when i lifted it. I just wanted to make sure I was not going to have any vibrations...
    The purpose of it is to relieve the driveshaft angles, and prevent/cure any resulting vibrations.
  3. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    What he said...had to drop mine after lifting to help with the vibes. I need to find out how to adjust shifter now though, it seems to not like going all the way into park /forums/images/graemlins/dunno.gif
  4. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    What do you use to drop it? just some longer bolts and a 1" of washers ah aha?
  5. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    On my 87 K5, all I had to do was put a jack under the t-case, loosen the bolts, lower the t-case, and put the metal spacers on the other side of the frame. Didnt take but about 20-30 minutes.
    -Harrison
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    On mine, I used a little fabbed up kit that was made for it. My cousin owned an off-road shop for many years here and he had it laying around. He gave it to me for free when I mentioned I wanted to lower the T-case when I did the lift. It was actually made out of thick walled square tubing, and already had the longer bolts etc.
    Now that I have this new Blazer I'm going to have to see if I can still get stuff for cost... hope he still has all his contacts. /forums/images/graemlins/thinking.gif /forums/images/graemlins/woot.gif
