Transfer case drop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr. Jimmy, Mar 14, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    I have just bought an 89 GMC Jimmy that has been lifted 6 inches with 35 inch tires and 1 inch trans case drop. I am experiencing some vibration at around 60 mph when I let off of throttle, this is the only vibration I notice. My question is can the T case be dropped safely more than 1 inch?
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I wouldnt go any lower...it puts extra strain on the motor mounts to have the engine angled too much.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Anymore than that you might shove the distributor into the firewall. I wonder if you could bevel the spacers to angle them back a little more than usual tho?! Like maybe 3/4" in the front and 1" in the back. Justa thought.
  4. monypit
    monypit Registered Member
    Mar 13, 2002
    16
    Peoria, AZ
    I would have your driveshaft balance check and if you don't have a cv joint in it it may be time to upgrade.
