transfer case fluid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by delta9blazer, Oct 24, 2002.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    how would i go about checking the level of fluid in there? does it use the same stuff as the tranny? if the tranny is full, am i OK? are you OK?
    oops.
    forgot the vitals:
    '89 5.7 fuelie w/ NP241
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    take off the filler bolt and stick your finger in there and it should be up to the bottom of the hole as for what goes in it it depends on what you got.... /forums/images/graemlins/wink.gif
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    What fumes said...and it takes ATF.
    I think I'm OK... /forums/images/graemlins/rotfl.gif
    Rene
  4. delta9blazer
    1,646
    the big one kinda in the center, not one of the outer bolts holding the face on, correct?
    (testing the theory of no stupid questions...)
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just in case you don't know, the fill hole is found on the rear of the transfer case, near the top. The drain plug is towards the bottom. Since it's obviously been awhile since the ATF has been checked, I would recommend taking an hour and swapping out the fluid.
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gifIt is the one that is square not hex!!!
  7. delta9blazer
    1,646
    roger that. i always assumed that the same fluid circulated the xfer case and tranny.
    how much fluid would ya figure? any special additives?
    thanks much for all the prompt relplies, btw. /forums/images/graemlins/laugh.gif
  8. Can Can
    15,552
    136
    Actually the transfer case and the tranny have their own supply of ATF- one batch of fluid does not circulate through two systems.
    Last time I serviced my 208 it took around 5 1/2 litres to refill. I've never used any additives but my 84 is the family wagon and doesn't see any hardcore 4x4ing, so plain ol' ATF is good enough for me.
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The 241 doent take as much fluid, i think mine held 3 qts.
  10. RedneckK5
    RedneckK5 Registered Member
    Aug 15, 2002
    42
    texas
    what year did blazers start coming with the 241
  11. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    88 i believe...???
  12. delta9blazer
    1,646
    correct.
    it was an option first offered in '88, standard after that.
    http://coloradok5.com/specs.shtml
    what a bitchen site. /forums/images/graemlins/k5.gif /forums/images/graemlins/smile.gif
