Transfer case grinding? Help!
Discussion in 'The Garage' started by 87Mudder, Feb 9, 2007.
  1. 87Mudder
    87Mudder Registered Member
    Jan 13, 2006
    34
    RVA, Virginia
    Alright boys,
    '85 K5, NP208, 700R4....When I let off the gas and sometimes when I get on it, I hear a long grinding noise coming from the middle of the truck. It seems like there's play front to rear in the transfer case like maybe a retaining ring has come loose on that tail shaft. I took the tailshaft cover off and everything seems to be tight except for maybe a little play in the chain. When I put the case in (N) I can turn the tail shaft and sometimes it engages the chain and sometimes it doesn't?! Any suggestions on what the heck is goin' on! Thanks, Will
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I wish i could help But I cant someone will come along and help you soon
  3. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    How much lift you got? My 241 was doing the same thing. It went away when I put the spacers between the crossmember and frame.
