Transfer case grinding mystery solved?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieRed, Mar 25, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    It just now occurred to me what could possibly be the problem in my transfer case. When I reinstalled my front driveshaft i noticed that the CV joint made contanct with the crossmember. i had also noticed only when it is in 4 wheel drive (with hubs locked) it would grind. Could this cause the really loud grinding?
    Also- from what i have recently found out, I may actually have the part time mod, but was not old when i bought the truck. it seems that i don't need to be in loc to run with the front hubs unlocked. also when the transfer case wasn't in lock the other day the front output shaft on the case turned freely while the rear didn't move. i still have four positions though? could someone have done an incomplete job and left for shifter positions?
    thanks
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Sounds like a part time kit as long as the front otput doesnt move when in the farthest shifting positition either way. (4wd lock low,2wd low, N, 2wd high, 4wd lock high)
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    but could the CV joint cause the grinding?
  4. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    you might have your crossmemeber backwards, it may look completely symmectrical but it may not be. Mine has a dent for the CV flange to clear the xmember from the factory. I know this becasue I had the same problem as you after taking it out and puttin gi tback in.
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    if i take it out the transfer case won't like fall out will it?
  6. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Yes, you have to support it with a jack or something then pull the x-member off. Later
    -fLeXy K20
