transfer case help
Discussion in 'The Garage' started by 4x4gator, Jan 16, 2007.
  1. 4x4gator
    4x4gator Newbie
    Jan 16, 2007
    oklahoma
    I have an 89 Blazer, which has had several parts replaced. I couldn't begin to guess which is orginal, and which has been replaced. By best guess I have OEM motor (350 TBI), trans (th700r4), xcase (unsure), and axles (again, unsure).
    I just had tranny repaired and was told it was an th700 r4, but they didn't know which xcase it was.
    My problem is this: I would like to know how to tell which xcase I have, which fluid goes in, and where can I find info (w/ pics if possible) on how to rebuild my xcase. It's leaking fluid (slowly) between the front tranny connection plate and the case. I'm assuming the gasket just needs to be replaced, but while I have it opened I'd like to make sure nothing is broken or missing.
    Any help will be forever appericated......:bow:
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    kinda hard to guess what it is w/out seeing a picture or u giving us a description of it. also hard to give u any rebuild advice w/out knowing which case it is?
    why don't u take a picture of the back of it & post that. then we could help u better.
    your truck should have a 208 if it were stock.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I think an '81 would have a NP 241 in it....I believe it is on the back side, there is a round tag that tells you what T case you have....Just clean the area off and read the numbers....
  4. goldwing2000
    goldwing2000 Guest
    It's an '89, not an '81.
    But yeah, according to the CK5 spec page, it should be a 241.
  5. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    OOPs, I can't type....:doah:
