transfer case identification?
Discussion in 'The Garage' started by mr.bowtie, Sep 5, 2005.
  1. mr.bowtie
    mr.bowtie Newbie
    Jan 22, 2005
    GA
    the t/c that i have i believe to be a 205 but the tag is gone the truck is a 70 c10 on 4x4 frame, year model also in question? can anyone give identifing pionts for a 205Vs208 also any ways to find the year model of the frame (67-72) (73-87) I'm sure there are some differences. any asistance would be appreciated
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Can you take a pic and post it?
    Other than that, is it an Iron Case or Aluminum case? The old Rockwell T-221, NP205 and NP203 are all Cast Iron Cases. NP208 and NP241's are Aluminum cases. Start with that and we can narrow it down some more...
  3. mr.bowtie
    mr.bowtie Newbie
    Jan 22, 2005
    GA
    it is an iron case.
    to be honest i would know how to add a pic i can't even figure how to add a avatar
  4. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    This is what the back of a 205 looks like. The tell tale sing is the little round cover with 3 bolts.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I'm guessing your truck has the 205 as they are pretty common, but if by chance it has the Rockwell its pretty easy to spot. Its skinnier and taller than the 205, and has a weird starburst shaped cover on the rear. It also uses a weird adapter with a side cover and a 2 piece stamped steel pivot for the shifter handle (when used in married applications).
