Transfer Case in 4-Low
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Nov 1, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Lets say I needed to pull a fairly heavy trailer up a gravel driveway. About 3600 pounds, maybe a little more. I have an 84 Blazer with a 700R4 and NP208. Would it hurt to put the transfer case in 4-Low to with the hubs unlocked to pull the trailer up the driveway, so I could make use of the lowers gearing? Thanks.
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    it wouldn't hurt a thing.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That would basically put you in 2-low. That sends all of the torque, multipied by the low range ratio, to just the rear axle. In 4-low the torque is split 50/50 between the axles. So you do stand a chance of breaking parts in the rear end, especially with the stock axles. But since the driveway is gravel, you should be able to use 4-low with the hubs locked, to spread the load between them. /forums/images/graemlins/cool.gif
  4. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Ok, good. Cause I did it today. I left the hubs unlocked, so it was just like 2 lo. That way i didn't have to give it much gas to move the trailer.
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    When reversing my 21 foot trailer I always put it in "2-low"...it's so much easier on the clutch!
    Rene
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I see that you already did it, but I would have put it in 4wd low and kept the hubs locked, for better traction, and since you are on loose gravel, you need the traction and there is no bind.
    Good to hear it worked.
    /forums/images/graemlins/thumb.gif
  7. dyeager535
    26,980
    And gives me plenty of time to sort out which direction I need to turn the steering wheel to get the trailer to go where I want it /forums/images/graemlins/smile.gif
