Transfer case indentification??
Discussion in 'The Garage' started by UofA_Blazer, Apr 9, 2006.
  1. UofA_Blazer
    UofA_Blazer Guest
    How can you tell the difference between a np203 and np205 from the outside? The last to trucks I was looking to buy fell through, I'm now looking at a 77 Jimmy with a "high sierra towing package" and I'm trying to figure out which TC it has. I've search for about 30 minutes without finding the answer.
  2. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I believe the linkages on the side of the transfer case are different, but I'm no expert either. My truck is a Jimmy Sierra 1974 and it has a 203 if that helps any.
  3. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    look for the id tag and the rear of the t case. you might have to wipe away some grease and sludge, but it shoul dbe there.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    See if this guide helps. ORD id a good job of laying it out.
  5. UofA_Blazer
    UofA_Blazer Guest
    I found this number on the rear passenger side of the TC: 4890. Is there a list somewhere that I can look this up.
    Cbbr: Thanks for the posting that link it's very informative, but I'm a little confused. The TC looks like the 205 from that picture and the truck has manual hubs, but I don't remember seeing a plate w/ 3 bolts and the shifter settings are H-lock, H, N, L, L-lock which would indicate 203.
    Thanks for your time.
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If the tcase is really long, its a 203, if its short its a 205. Any thing is typically (unless its been swapped) 203's came behind auto trannies and 205's came behind manual trannies. Just because there are hubs on the front doesn't indicate anything. Could mean that the owner has put a part time kit in a 203.
  7. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeppers, main 3 things I look at are: the shift linkage, the 3-bolt idle gear cover thingy, and the rear output seal retainer. On the 205 the shift linkage attaches to the top-center on the front of the t-case, on the 203 its further forward and on the side of the range box. On the back side of the case, the 205 has the 3-bolt cover, the 203 doesn't. Lastly, on the 203 the rear output seal/retainer thingy is much longer, while the 205 one is short (less than an inch).
    as noted by others, manual hubs aren't a sure indicator... thanks to the milemarker part-time kit for the np203.
    j
