transfer case jumps out of 4h
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by will89, Nov 7, 2002.
  1. will89
    will89 1/2 ton status
    Oct 21, 2002
    104
    nomad
    When I decelerate the t-case pops out of 4h. Its an 89 sub with manual hubs. Does this mean the t-case chain is too lose?
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    How is your truck lifted, suspension or body lift?
  3. will89
    Oct 21, 2002
    104
    nomad
    just a 4" suspension lift....still has stock body mounts
  4. Mikeyg79
    Mikeyg79 Registered Member
    Aug 3, 2002
    83
    My friend has a 3/4 ton with a 208 (maybe what you got) that had problems not going into gear and popping out of 4h. I believe it started out as being a spanked shikft fork (then there were tail beatings that broke other stuff, but that is another story.)
    Check the fork and the shift adjustment.
    Mikey
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    As Mikey said, sounds like a shiftfork. Mine did the same and we had to open the transfer and change the shiftfork.
  6. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Is your t-case dropped? if it is adjust the linkage. /forums/images/graemlins/eek.gif Do a search and you will find out how /forums/images/graemlins/rolleyes.gif
  7. will89
    Oct 21, 2002
    104
    nomad
    Nope..the t-case isn't dropped. Its a 1/2ton 350 and I think the t-case is a NP241?? Im not sure off hand though
