Transfer case leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83K5, Jun 2, 2000.
  1. 83K5
    83K5 Registered Member
    Mar 15, 2000
    24
    On my 83 I have had a leak where the rear driveline goes into the case . I've replaced the seal once . It's leaking again . When I move the driveline it will move up and down maybe an 1/8 of an inch . Is this normal or is something happening to the transfer case ?
  2. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Check to see if the slip yoke has a groove worn in it from the seal. Mine did and I had to replace the yoke. Problem solved.
    BIGJ
