Transfer case leak...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXBIGFISH, Mar 11, 2002.
  1. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    I have completely rebuilt my 208 about 6 months back. Now the question this weekend I replaced the front output shaft seal to fix the leak, and to no avail it still leaks, so do I need to go to the parts store and try to find a different seal that is tighter on the shaft or is it the shaft that is causing it to leak and I need to replace it?
    I just want to fix it so I don't have to rebuild it in the near future because the fluid got low and it burned up. Any suggestions?
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Didja put some RTV around the outside edge on the new seal? You sure you seated it all the way?
  3. TXBIGFISH
    Oct 2, 2001
    297
    Sachse TX
    Yeah, did all that it looks like it's leaking around the shaft.
    It's not pouring out, but a steady stream, about a quart a week.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Re: My solution
    Here is my solution. I went ahead and bought some sort of thick sink stopped gasket from a hardware store and used it on mine. I can look next time I go. Mine leaked as well until I cut and fitted the gasket and torqued it to the full 120ft lbs.....anything less than that 120ft-lbs and mine leaked as well
  5. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Re: My solution
    Similar problem here. Had my 208 rebuilt at clutch & U joint w/ a one year warranty. 8 months later the front output shaft started leaking, they replaced the seal. Later I put on the brace that goes from the T case to the engine, now it appears that my case is leaking where the halves join. does this brace really apply that much pressure? Or is it a different problem
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    your front output flanges seal surfaces are probly all jacked up . if thats not it the seal isnt the right one . then maybe it didnt get put together correctly.none of mine ever leak , until i grenade them /forums/images/icons/smile.gif !
  7. TXBIGFISH
    Oct 2, 2001
    297
    Sachse TX
    Ok here is a shot in the dark, what's the part number you got for the shaft? I don't have the one I bought here in front of me but I do know I paid $11 for it! The rear I bought is a National seal 9449 though.
    The front seal I bought is a 3946, I saw that they make a seal and shaft kit for it, what exactly is it and has anyone used it?
    PN# 99187
  8. Snowbound
    Snowbound Registered Member
    Mar 12, 2002
    52
    Minot N.D.
    I had the same problem awhile back. Replaced the front seal
    on the transfercase and it started leaking again. there is a little rubber star shaped washer behind the nut on the front drive shaft flange. This is where mine was leaking from.
    of course dealer only item. I hope this helps
  9. TXBIGFISH
    Oct 2, 2001
    297
    Sachse TX
    Nope I replaced that, had a spare form the rebuild kit.
    It is definately the front shaft seal, I guess I will have to get a new front yoke unless anyone knows of another way to fix it.
  10. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    go talk to napa ... if that yoke is worn a little the seal will hold for a little while and then start to leak again (like my pinion yoke on my 10 bolt*). They have a nifty patch ... its a thin band of metal at a specific diameter that you "pound" onto the yoke "neck" to get it back out to the original diameter. Then the seal seals up good and doesn't leak. They're pricey (25-30) ... but after replacing 4 seals on my pinion I was ready to try anything
    (* - I know that the solution to any 10 bolt prob is a 14 bolt ... )
  11. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I think (big emphasis on the think) that the items at NAPA are called Speedy Sleeves, and they do work well as I have seen them in use on farm equipment and they don't leak.
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    That gets expensive on the front axle /forums/images/icons/crazy.gif, sorry just had to say it /forums/images/icons/smile.gif
  12. TXBIGFISH
    Oct 2, 2001
    297
    Sachse TX
    Thanks, I'll look into it.
    Looks like I've got a project for the weekend!
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You should have tried a new pinion yoke.
