transfer case leakage
Discussion in 'The Garage' started by Mad Mac, Oct 20, 2002.
  1. Mad Mac
    Mad Mac Registered Member
    Jun 10, 2002
    22
    M, I, Crooked Letter, Crooked Letter, O, U, R, I
    why is my np241 leaking?
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    LMFAO!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Like, where is it leaking from??? /forums/images/graemlins/crazy.gif
  3. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Because it wants to?
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    its only a matter of time before a seal is used too much and wears out.find out where it is leaking and put in a new seal.some times bolts are loose and just tightening then a little will stop a leak also
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    if its the slip yoke, ive heard that is a pain the the mass to fix, and it costs like 75$ for a new one, mine leaks on my 208, i was thinking of taking the driveshaft off and cleaning out the slip yoke REALLY good and putting some "the right stuff in there" insulateing foam and packing it down in there so it will form a barrier and not leak, anyway good luck.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    its a OEM design. Prevents underbody rust by slinging ATF all over the place! /forums/images/graemlins/rotfl.gif
  7. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    that does actually work!!! there's no rust on my rig /forums/images/graemlins/smile.gif
  8. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    your in texas too!!! That doesnt count! im in NY!
    The only rust was in the tail pan area. (the only area without a leak). The engine compartment is rust free too. A little leaky valve covers does wonders. So does that old bottle of motor oil in the wheel well....
  9. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Its called automatic chassis lube /forums/images/graemlins/rotfl.gif
  10. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    lol never thought of it as UNDERBODY RUST PROTECTION, heha, good one everybody. /forums/images/graemlins/thumb.gif
  11. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    yep...next you all will be spraying the bottom of your trucks with 10/50 weight /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
