transfer case linkage problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trukker, Sep 4, 2004.
  1. trukker
    trukker 1/2 ton status
    Aug 3, 2003
    257
    Sebastopol Mississippi
    I just got thru swapping my 700r4 /208 for the th400/208 combo, and need some t-case linkage help. Are certain year surburan and blazer linkages the same?. The transfer cases seem to have the same shift pattern, But the burb case has a diffrent throw angle than the blazer case. The tranny and case came out of an 87 burb the blazer is an 89.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Isn't there an adjustment on the bottom where you can make it work?
  3. trukker
    Aug 3, 2003
    257
    I tried that , When in 2 hi the piece on t case is at 12 o'clock. when in 4 lo it's at about 3 o'clock. There isn't enough range of motion in the whole linkage assembly to make adjusting it work.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You could get a piece of tubing as a sleeve for strength , and weld another section of threaded rod on . Then it would be long enough /forums/images/graemlins/thinking.gif
  5. trukker
    Aug 3, 2003
    257
    Actually the rod is too long now. It's the piece thats on the t/case thats too short I think . I haven't had time to really see what it needs.I was just wondering if the linkages were diffrent between the burb and blazer.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The linkage is likely not different. It's probably because the TH 400 is shorter than your old tranny and that's why you're having issues.
    It's not due to the body it's in.
  7. trukker
    Aug 3, 2003
    257
    I had heard that the 400 was shorter and I would have to do some driveline modifications but mine bolted up in the same location on crossmember and all drive lines were same length. Sooooooooo.. Custom linkage here we come! /forums/images/graemlins/grin.gif
