transfer case maintenance question
Discussion in 'The Garage' started by thfonz98, Mar 16, 2006.
  1. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
    ok i have a stock 91 k5 silverado which im second owner(my grandfather was previous owner). Truck's had great maintenance EXCEPT i think 4 wheel drive has only been engaged maybe twice ever(once was just to disable the antilock brakes). My grandfather has alway kept the fluids changed(TC, tranny, motor, axles, etc.).
    how often should i throw it in 4high just to keep stuff in good running order or is there a need?
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Sometimes the front driveshaft will help you out by rotating from residual drag ( therefore letting the shaft/sproket in the case turn and splash some oil ) but do not count on that.
    I use a rule of around once a month to drive down a dirt road for just a half mile , or so , in 4WD ( hubs locked optional ) just to let the gears/chain spin and sling oil all over to keep the internals coated as best they can.
    Tom
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Good advice, you don't want your internals rusting inside.
