Transfer case mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan2286, Mar 17, 2003.
  1. Ryan2286
    Ryan2286 Registered Member
    Nov 7, 2002
    32
    South Suburbs of Chicago
    I found out what my problem is. When I give some throttle the whole Tcase lifts up a good two inches. I recently replaced the motor mounts but no I see the problem must be the rubber mount that connects the Tcase to the cross member.
    Where can I get a new and better mount? I want a polyurethane one because thats what my motor mounts are, Also what is the actual part name. I told the guy at the dealer it was the transfer case to crossmember mount and he said he knew what I was talking about but couldn't find it on the computer. Is this actually refered to as a trans mission mount? Thanks for any help. -Ryan
  2. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    PM or e-mail Boscolingus, he can be found in the User List. He was developing a polyurethane transfer case mount and may be able to help you.
  3. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    4 wheel parts has just what you need. my buddy put them in his blazer a year ago. i dont have the number sorry.
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Get the polyurethane mount from Energy Suspension Part #3.1106R You can get it from summitracing.com
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I think he has the new style mount on his '88. The 3.1106 mount is the early style.
  6. Ryan2286
    Nov 7, 2002
    32
    After what year did the style change and where can I get a polyurethane one for my 88. Also are these called transmission mounts or transfer case mounts?
  7. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Just how much play should there be in the Transfer case. I was out teaching my son the finer points of snow wheeling and when he got a little hung up and not moving with the tires spinning I could see the transfer case moving up and down. The mounts are less than a year old. same with the tranny mounts. I also am running a 241 with a slip yoke eliminator and Jess's High Angle 1 ton shaft. Not that any of these should make a differance. I did inspect the mounts and they still appear to be attached. /forums/images/graemlins/confused.gif
  8. dyeager535
    26,979
    Usually called transmission mounts, but also believe GM called them rear engine mounts. Whatever, just make sure what they sell you looks like the one on the truck now. Only thing that will probably vary is the color.
  9. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    '68-'84 uses the old style mount 3.1106.
    '85-up uses the new style mount 3.1129.
  10. Blazer79
    1,816
    Sorry for not reading. /forums/images/graemlins/blush.gif
    I would have hated myself if you ordered the wrong part because of me. /forums/images/graemlins/eek.gif
  11. Boscolingus
    Boscolingus 1/2 ton status
    Nov 26, 2001
    210
    Santa Clarita, CA
    A while back I posted to see if there was an interest in producing these mounts in poly form for the hardcore enthusiasts. I went ahead and installed the prototype on my truck and it is holding up DAMN well. I have a few dimensions left from when I made it, however there may be some more dimensions I need to make up another unit as I pitched the fixture to make these guys thinking there was not a demand for them. I will have to see if I still have the pictures of the mount, but if I dont I will crawl underneath the truck and get a good shot at the unit I have.... lemme know which way you want to go, the Energy Suspension unit, or the bullet proof unit =-)
  12. Ryan2286
    Nov 7, 2002
    32
    what would be the problem with just a steel mount? If people use motor plates why not mount everything as rigidly as possible?
  13. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    motor plates are for street cars that see flat surfaces. you are driving a truck that see's unever surfaces all the time. the suspension soaks up most of it but the frame does too, especially when you get real twisted up. imagine your frame trying to twist and you drivetrain not cooperating...I see some unhappy housings cracking.
    -Scott
