Transfer case-NP 208 Rebuild or Replace?
Discussion in 'The Garage' started by shadow6000, Feb 4, 2007.
  1. shadow6000
    shadow6000 1/2 ton status
    Jan 2, 2006
    126
    North Wilkesboro, NC
    I drained the fluid out of my 208 last week and got these nice little bearing pieces that came out with the fluid.:doah: This is in the '85 K5 with the SM465. What can I put back in there without doing major modifications? I.E. what spline count, long shaft or short shaft, etc... I'm not doing any major 4 wheeling so I'm not opposed to another 208.
    The other question I have is whether I should just rebuild the case I have. I don't know what's wrong with it other than the bearing pieces that came out with the fluid change. It still shifts fine and as far as I can tell the 4x4 works.
    Thanks for your suggestions.
  2. shadow6000
    Jan 2, 2006
    126
    Did I forget to type my question??
    C'mon guys. I know you've got to have some ideas about this.
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Just put another 208 in there or rebuild the one you have, that way you will know that no other mods will be needed. 208's are cheaper and easier to find than a 241, they work just fine, especially if you don't really do any wheeling.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    A 208 rebuild can be done in a few hours. Just rebuild it.
