Transfer case oil change
Discussion in 'The Garage' started by Stormin, Jun 4, 2005.
  1. Stormin
    Stormin Registered Member
    Apr 25, 2005
    35
    Redmond WA
    I'm trying to change the oil in my transfer case. I believe it is a 203. I have the 2wd low range, does that mean it has to be a 203? I know it's not a 205 but I don't know what the 208 or 241 look like. Anyways, I need to know what type of oil to use in it. I heard that they use motor oil but the oil that came out of it looked (and smelled) an awful lot like 90w gear oil. Also, how often should the oil be changed?
  2. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    203 and 205 cast iron. and 208and up are aluminum. 203 full time 4x4. all others part time. what year truck and or kind of case to id it for ya.
  3. Stormin
    Apr 25, 2005
    35
    Redmond WA
    It's a 77 blazer 350/th350 and I believe it is a 203. Looks like one anyways. But it is not full time 4wd. Just really need to know what sort of oil to put back in it.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Probably a 203. I think a 205 has a drain plug, and a 203 doesn't.
    A local 4x4 shop told me to use 10W40 in mine when I had it.
    :xmas:
  5. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    Does it look like this? http://community.webshots.com/photo/183256651/183257088kAJBFL
    No oil drain plug? This is the 203. If so, undo the bottom bolt, drain, and refill with whatever weight you are running in your truck. I use to think I should use 90w gear oil, but learned better through this site.
  6. Wes Harden
    Wes Harden Registered Member
    May 28, 2005
    29
    Southern Califorina
    I'm running 80-90wt gear lube and 30 to 40% lucas in my np205 and my dana 21's. been thinking about running 100% hd lucas in them anybody else do this ?
    Wes
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you have 2wd low range , then you would have two shifters , one for hi/low and one for front/rear , custom , not factory , and can't be done to a 208 or 241 at all since its got one lever like an auto tranny and does everything internally in a way you couldn't do it with two shifters .
    Or it is a converted np203 , to part time .
    We all technically have 2wd low if we don't lock our front hubs with anything else :D
  8. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    Hmm, maby now i'll go outside and see what transfer case I have too.
  9. google
    May 19, 2005
    805
    Arizona
    I have a 208 stamped 1981. Is that a good thing or a bad thing?
  10. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    As far as fluids in transfer cases is as follows
    203 = 10-30 0r 10-40 oil
    205= 80-90 weight oil
    208 = atf tranny fluid
  11. Stormin
    Apr 25, 2005
    35
    Redmond WA
    Thanks for all the info guys. I think I'm finally starting to get a grasp on the differences between all these transfer cases. One more question though. How often should the oil in the TC be changed?
