Transfer Case OIL..gettin ready for hollister this weekend!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by breyon55, Sep 24, 2001.
  1. breyon55
    breyon55 Registered Member
    Aug 19, 2001
    30
    Fremont, Ca Northern Cali
    Ok Im headin out to hollister this weekend and I wanna adjust the transfer case and add new oil. What does everyone recomend putting in and any tips on adjusting a np203? thanks..brian
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    NP203 uses motor oil - use whatever you run in your engine.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. k5wantabe
    k5wantabe Registered Member
    Sep 3, 2001
    30
    So. Cal. Lancaster
    How about an np208c? What should it have. I just bought the Jimmy and appears to have tranny fluid.
    '88 Jimmy 350/700r4 3.73's 32in Maypops
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Yup!! Dexron/Mercon tranny fluid in 208's and 241's.
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    What day you heading down here to Hollister? Dunnerunner had been trying to set something up. He lives up in Fremont with you.. I live here in Hollister and I might be able to break away for a while and meet you there.. I am putting on a new carb this weekend and I need to test it out...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    The Haynes manual recommends: NP203 10w-30 engine oil NP205 80w-90 gear iol NP208 Dexron II or equivalent automatic transmission fluid. i found that on off-road.com
