Transfer Case or Rear end broken? (NP208/10Bolt)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, Jun 25, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    There is this metalic popping noise coming out from under the truck when I put it in gear. I can hear it going from reverse to drive or vise versa.
    I can also hear it when I drive it down the street.
    I can't tell whether it's coming from the rear or the t-case. I had someone do it while I watch and listen but still can't tell. Also did it in 4wd but still the same. I guess I'm gonna have to pull the diff cover to see if everthing looks cool in there.
    How do I inspect the Tcase? I checked the fluid and it's good.
    Thanks,
    Chris
  2. troyboy
    troyboy Registered Member
    Mar 13, 2003
    13
    could be a rusty u joint. they can make a tingy ,cracking sound and still feel tight. look around the ujoint caps for rust stains
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Might be the rear end, does it have a G80 on the option code sheet? That would mean it has a Gov Loc and that might be your problem.
  4. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Thanks guys. I guess it was just a broken u-joint. Seemed fine when I first looked at it but after shaking it up for a few minutes the seal came loose and fell off.
    So, I went to Kragen b/c it was the closest place to go to and they gave me the wrong u-joint. /forums/images/graemlins/mad.gif
    Guess I'll be at it again tomorrow.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hey cool, if thats it then you're on your way to blazerfest...
    If ya can't do that ujoint yourself, take it to Scott's shop and have him change that ujoint for ya. He should be able to help you to get you going to blazerfest...
    See you out there brah! /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/pimp1.gif
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Thanks for that info I was just about to do a search on G80 code to see what I got in my 14bff.
    It's my tow rig and it's staying with stock tires and all so I should be fine, no danger in breaking it, and it's a bonus to have a locker.
    /forums/images/graemlins/grin.gif
