Transfer case problem. any ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scottnj, Apr 13, 2002.
  1. scottnj
    scottnj 1/2 ton status
    Aug 4, 2001
    112
    Central Florida
    I have a 1991 Chevy Blazer.
    When I put it in 4 HI soemtimes it will slip back to 4x2.
    I think maybe this started after I did a suspension lift.
    Would something not be letting it go all the way into gear?
    It was a 4 inch lift. Thanks. scottnj@cfl.rr.com
  2. Grim-Reaper
    7,385
    Atlanta
    If you lowered the case when you did the lift then yes that's the problem. lowering the case changed the angle the linkage is at and it needs to be readjusted some.
    Welcome to CK5
  3. scottnj
    Aug 4, 2001
    112
    Central Florida
    Thanks for the help. I did lower the transfer case some. Any special way to adjust the linkage?
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    9/16 wrench, 2 of them. 2 nuts on the linkage rod, connecting the shifter to the T-case.
  5. scottnj
    Aug 4, 2001
    112
    Central Florida
    Thank you again. Will give me something to do this weekend.
    Scott
