Transfer case problems
Discussion in 'The Garage' started by no_3of4, Nov 16, 2006.
  1. no_3of4
    no_3of4 Newbie
    Nov 15, 2006
    texas
    Hello all, I am new to this but I have a 86 k-5 blazer. It has a np 208 in it and 78 350. I dont know much about the transfer case part of the vehicle. But when in 2 wheel it runs fine but if i engage 4hi and lock the hubs it pops under the body, sounds like the case, but not sure. In 4 lo it really make a noise w/o even engaging the hubs. Any thoughts would be appreciated. Thanks..
    no_3of4
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Is the truck moving while you shift, or do you shift at a complete stop?
    Does the noise only happen when you turn hard?
  3. no_3of4
    no_3of4 Newbie
    Nov 15, 2006
    texas
    I am at a complete stop when i change. It is is smooth switching between 2 and 4 but when in 4 wheel it makes noise. If i am in 4 hi and try to climb it gets worse. almost like the chain is slipping? I dont know if there is a linkage adjustment that may be out? but as far as turning it is fine.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I bet your chain is slipping....Time to open the case and rebuild
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    as a quick check before you pull the case, make sure you check your u-joints. probably not the issue... but just in case. it's a lot cheaper/easier! i don't remember if the driveshaft for the front axle has a ujoint at the t-case - if it does, that'd be the first place i'd check.
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    check the ratios of both axles..
    It might be your truck had an axle swapped in that does not have the same gear ratio as the other,that will cause binding and something has to "give",usually a hub releases with a loud bang,or the transfer case chain might jump over the sprockets if its loose enough..if the truck feels like its binding in 4wd,this is a very good possibility..I had a 71 K5 I bought that had a 3.08 rear axle, and a 3.73 front!--needless to say it was useless in 4wd!:(
    Also ensure all 4 tires are the same size--MEASURE them with a tape measure around their circumfrence,don't just assume they are all the same just because the sizes printed on the tires match--I've seen many tires of different brands LABELED as "235/75/15,for example--but when you measure them,one brand will be up to 2" in diameter different than another brand!..:doah:
