transfer case question.
Discussion in 'The Garage' started by RubberFloorMat, Jan 27, 2005.
  1. RubberFloorMat
    RubberFloorMat 1/2 ton status Premium Member
    Dec 12, 2004
    395
    43
    Oklahoma
    91 Blazer
    transfer case rear cone seal,
    what do i have to do to change it, just pull the driveshaft and put a new one in?? or do i ahve to take the thing apart?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Are you talking about the seal at the tip of the cone where the driveshaft goes in?
    Just take out the shaft and replace the seal, then put the shaft back in. I always put tranny fluid on the seal and shaft yoke before putting the shaft back in.
  3. RubberFloorMat
    Dec 12, 2004
    395
    43
    Oklahoma
    the seal where the cone mounts to the case..
  4. divorced
    Jul 20, 2004
    5,115
    Can't help you there, never messed with that. Someone else will know... :ears:
  5. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    I've never done this, but I'd imagine when you take it off that you can seal it up with rtv black... thats what everyone is telling me to use to put in between my 208 and the adapter. Although I dont know what in tails taking of that tail shaft cover.
  6. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    I used RTV black when sealing the tailsection back onto the case, as long as you clean off all the tcase fluid you'll be alright.
  7. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    If it's an NP208 there is no gasket and the factory manual calls for RTV. I just had mine appart last summer and was supprised to learn that there was no factory gasket.
