Transfer case question???
Discussion in 'The Garage' started by Supreme70, Dec 6, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I want to know how much fluid to put in a 208 and what type of fliud and which is the whole to fill it up, ones high and ones low????:confused:
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I just use strait gear oil, and fill it up with the top hole and fill it till it comes out.
  3. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    top is fill hole bottom is drain
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the np208 uses ATF, and i think its 4.5 quarts, havn't done it in a while.
  5. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    ATF of Dexron2 or better standard. I've used gear oil in a pinch, but hear that its not a good idea in the 208. it will take 4.5 quarts to fill to the rim of the fillhole
  6. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    4.5 quarts sounds about right. thats about how much i put in mine today, i used dextron III/mercon stuff.
  7. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    thanks guys now i can get my truck up and running. Happy holidays all.
