transfer case question
Discussion in 'The Garage' started by beater_k20, Jan 10, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    so say someone were to want to run different gear ratios in a truck, and compensate with tires to offset the gears, so they're close. how much difference is too much? factoring in tires, i've come up with just under 1% difference, with the lower ratio being in the front.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    FWIW, the tires in question are 35 x 10.50 x 15 Boggers, with 3.73s in the front axle, and 38.5 x 15 x 15 Boggers with 4.10s in the rear.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think 1% difference is acceptable.
  4. AV8
    AV8 Registered Member
    Oct 8, 2005
    45
    Winston Salem, NC
    I read an article about this years ago. IIRC you can have more than 1% difference just by your tires having unequal tread or not having equal air pressure. I don't think 1% will cause you any problems.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    anybody else?
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I've heard the same, that right around 1% is acceptable.
    However, in my own personal opinion, with all the loose surfaces we drive on and the tire speed we use, you could probably go with a lot more differentiation and not do damage.
