Transfer case question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89K5guy, Jun 12, 2006.
  1. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    A friend of mine is giving me a 208 transfer case FREE:D .My question is will it bolt up to my 89 K5 blazer?I obviously have the 700R4 trans.I figure it will bolt up but what all is involved?The 208 came out of a 1986 truck.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    The 89 should have a 241. Why would you want to swap from a 241 to a 208? Unless the 241 is toast, I'd keep it. But it will bolt up, shifters are different and probably the torque rod may need some modifications.
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Should be a straight bolt in. I have an 89 241 case in my 86 K-5.
  4. wkbrdrob
    wkbrdrob Registered Member
    Feb 7, 2006
    63
    Salem, OR
    did you have to change anything on the '86 chassis to make the '89 241 work?
  5. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Nope, the case was a perfect bolt-in. The crossmember, and transfer case support both fit exactly like they did on the 208. Heck, I didn't even have to adjust the shift linkage....
  6. wkbrdrob
    Feb 7, 2006
    63
    Salem, OR
    sweet!
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    You do know like ryan22re said.... the 241 is a better case than the 208 ever thought about being. Just to let you know.
  8. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I agree.....the 241 has a better low range, has an oil pump mechanism instead of a slinger, and you can get a SYE for a 241 (which is why I swapped in one in place of my 208....
  9. linksvu
    linksvu Registered Member
    Jan 7, 2006
    89
    Littleton, Colorado
    Now we would be having a different conversion if your friend gave you a free 205......
    Does he have anything else worth-while he is parting with?:D
  10. 89K5guy
    Jul 11, 2005
    174
    Ohio
    If he does i will certainly post it here!;)
