Transfer case Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Elwood Blues, Aug 13, 2001.
  1. Elwood Blues
    Elwood Blues Newbie
    Aug 13, 2001
    Im looking to switch from a 203 to a 205 in my 79. It has a turbo 350 transmision. I have access to a 205 that was mated to a 4 speed. My 1st question is can the coupler be changed from an automatic model to make this 205 work?
    My 2nd question will the coupler from a 203 automatic work on the 205 that was meant for straight drive?
    I know I can take all this stuff apart and figure this out but I was hoping someone had already done this to save me alot of unescesary work.
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    input gear on the 205 is different
    there is lots of info here <a target="_blank" href=http://community.webshots.com/album/13852561QnRQRdZuCQ>http://community.webshots.com/album/13852561QnRQRdZuCQ</a>
    click on the images to enlarge the size once then select how big you want it to be where it says 'fit to window'
  3. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    A Blues Brother?!?!?!!?[​IMG]
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Just as an aside, what's the reason for this swap? Is the 203 dead? If not, then going to the 205 won't net you much. Both cases are strong as pigs breath and low range is nearly identical between them. If you want to just get rid of full-time 4WD, then just install one of the conversion kits in the 203 and not have to hassle with driveline lengths, adapters, etc. [​IMG]
