Transfer case Question?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by RingMaster4x4, Mar 27, 2002.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Does someone makes 1 ton yokes that will fit on a 1/2 NP205?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    High Angle Driveline (530) 877-2875 www.highangledriveline.com
    I just ordered a 1 ton CV from them and a e-brake that mounts to the t-case.
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    what did that cost you?
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The driveshaft was 420
    The Flange was 110 (a bit more than standard because they have to do some extra machining to get it to work w/ the e-brake)
    The e-brake kit was 270
    This is a bit more than I was looking on spending but I am running rear disc and wanted a e-brake that actually worked.
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Thanks for the info I will be calling them when I put my 12" lift on.
