Transfer case question
Discussion in 'The Garage' started by Z3PR, Apr 11, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I don't know much about 4x4's. I just recently bought a 76 K/5 Blazer. It is all factory original. It's got the 400/400 combo. What transfer case would it have ??? It's full time 4 wheel drive. Also, what all would be involved in converting it to part time. Right now I've got (high, high-lock, low, low-lock). Would you recomened this conversion ??? This is my daily driver that see's alot of street and highway use. I do plan on off roading with it.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    That would be a New Process (NP) 203...It has a cast iron case, is chain driven and had a 2.00:1 lowrange...As you stated, it IS a full time t-case...I think MileMarker or somebody like that has a kit for around $100 to convert it to a part time t-case...
    Chris
  3. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    fortcollinsram is right, that is a np203. But about recomending the part time kit or not? I don't know. Some people swear by them but I personaly have ran full time for some time, after getting rid of my part time case. I didn't see any better gas mileage with the part time and am not going to convert mine.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I never heard of a 400 tranny in a Blazer. Only in the 3/4 ton trucks.
    I also never heard of a 400 tranny back in '76 models. I thought TH400's came out in the trucks in '77.
    Don't take my word for all this info though. /forums/images/icons/tongue.gif
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is what I was thinking too. I was thinking it should be a th350. I may be way off base though.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    If that tranny is the 400, then I would almost bet that someone else swapped it in there.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It may be a th350, I was assuming it's a th400, but I may be wrong. I'll have to climb under it and have a look. I'll do a follow up post in a few mins. Let me go look.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    if it looks like a square with one cornor lopped off, its a TH350
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    the pan that is.
    Also if the pan looks like Texas then it is a 400.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I just climbed under the Blazer. It's a th350.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What all would be involved in installing the part time kit ??? Or should I have a shop do it ???
  12. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    I had a 74 K5 with 400/350/203 with full time. It worked great, I ran it for four years. It did bind a little on tight corners. I did finally break the left front axle shaft just going down the highway but I think it was from some jumping I did with it prior.
    I had planned on doing the swap to part time and back then it could be done for about $200.00 installed. It involves obviously new locking hubs and then there is a part that has to be installed in the transfer case.
    As soon as I bought mine I put a modified 400 in it and smoked the tranny so upgraded tranny and had the chain and seals and what ever else looked bad on the transfer case done.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Is this something that anyone can do in the driveway, or is it best taken to the shop ??? I've never done this type of conversion befor.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm also consittering getting a doubler from ORD. I just need to have a rich relative keel over and leave me some mulla.
  15. gtkustoms
    gtkustoms 1/2 ton status
    Oct 6, 2001
    281
    nm
    thatk30guy
    turbo 400 were available in 75 my grandpa ordered it from the dealer that way btw its a 3/4t 4x4 with np203
