Transfer case question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FunBlazer, Aug 3, 2002.
  1. FunBlazer
    FunBlazer Registered Member
    Jul 30, 2002
    29
    Lake George, NY
    My transfer case keeps popping out of 4H and going back to 2wd /forums/images/icons/confused.gif . It's a 87 w/700R4 & np208 is this a normal thing or is there a problem somewhere. I'm new to this 4x4 sene, so some of my questions may sound a little dumb to you expirenced people. Thanks in advance for any input.
  2. dremu
    Feb 27, 2000
    15,966
    458
    East of San Francisco
    The only dumb question is the one you don't ask.
    I gather that this happens on the older NP203's ... I've been fortunate that none of mine have so far. Solution is to adjust the control linkage, which can get out of whack with the body shifting over time.
    I'd imagine that the general procedure is the same for yours; I'd get under the truck and have a partner shift the lever back-n-forth, and watch to see how it works.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    My original 208 had this problem. I took it apart and found that there was a rod that went from the front of the transfer case to the back. this rod was about at the center of the case and the shifting stuff ( lack of a better discription, forks mabey) slid back and forth on it. The back of the rod sat into a boss in the back of the case and the boss had been wallered out causing all the shifting stuff (again) to become very sloppy. I just got a new back housing piece from junkyard and changed it. Did the whole thing while it was in the truck.
