Transfer Case Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sickquad, Aug 19, 2003.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    So, I have a np203 with auto hubs in my newly acquired Blazer. It also doesn't have a front driveshaft in it currently. I drove the rig home, 40-50mph. This means that the case has the conversion kit in it already? I have searched the forum, so much info, but I think I have just confused myself even more.
    I believe that if it doesn't have the conversion kit, without the front driveshaft it should just slip and not go anywhere. It also chirps the tires when you put the skinny peddle on the floor. The person that I got this Blazer off of, for free, knows absolutely nothing. Can someone set me straight?
    Chris
  2. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    Well, if you drove it anywhere with the Transfer Case "unlocked", it definately has had some changes..
    The NP203 "full-time" transfer has 4 "ranges". L/L-lock H/H-lock..these transfer cases ALWAYS are in 4x4
    A "part-time" transfer has 4 "ranges" ..L-2x4 / L-4x4 (frequently called lock) and ...H-2x4 / H-4x4
    These transfer cases are only in 4 wheel drive when the transfer case lever is in 4x4 otherwise they are in 2 wheel rear drive...
    The Full Time unit normaly runs through both diffs, with a differential in the transfer case splitting the drive front to rear..just like a front or rear differential splits the drive between the left and right wheels...
    Just like with a "non-posi" or "locker" diff, when one wheel is on something slippery and the other has traction the slippery wheel will spin,
    With the Transfer case "unlocked", if the front is on something slippery and the rear has traction the front wheels will spin and vise versa
    So the Full Time transfer has a Lock position to use on slippery surfaces
    If you run without the front driveshaft, and do not put it in Lock, it will not move.. If you Lock it.., it will move but the output shaft to the front diff will turn, even though is is not connected to anything...
    These transfer cases, while almost as strong as a 205, WERE NOT designed to run like this and it can break the locking gear inside the transfer case...
    /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  3. sickquad
    Jul 23, 2003
    785
    Ma
    The previous owner drove the rig like this for two years(without a front driveshaft). So if the truck is still going this means that it has had modifications in the transfer case. If it hasn't had modifications, from the previous post this transfer case should have broken by now? Is there any way for me to visually tell without opening the transfer case? I think I'll go out and put it in all positions and see if I can get it to slip. Any input is appreciated.
    Chris
  4. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    get under the truck and turn the front output shaft on the transfer case by hand. if it turns, and you just drove the truck, its got a part time kit. If it doesnt turn, then you A) dont have the part time kit or B) Have the part time kit but are "accidentally" in 4WD currently.
    mike
  5. sickquad
    Jul 23, 2003
    785
    Ma
    Thanks Mike, that is the exact post I was looking for, nice and simple.
