transfer case questions
Discussion in 'The Garage' started by 1986chevy_rider, May 3, 2007.
  1. 1986chevy_rider
    1986chevy_rider Registered Member
    Nov 8, 2005
    97
    fallon nv
    My 203 wont go into 4 high i can get it in to 4 low but not high what do I do got mud bogs next weekend.
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    You have a part time kit? WIth teh hubs locked try rocking the truck back and forth while trying to shift it in 4Hi. Does it go in all other gears? holla back.
  3. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    You should be able to adjust your tcase linkage, get a Chiltons or Hanes manual and it will walk you through it.
  4. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    Well its kinf of rigged they put on hubs to lock and the x-case doesnt have part time kit in it. but I think I can get it in to all the low gears and thats it.
  5. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    That doesn't sound right???????
    I thought to have lock-outs/hubs you had to install a part time kit? Maybe someone else can jump in and tell you.:confused:
  6. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    the drive line still spins just not locked at the hubs
  7. 1979chevystepside
    1979chevystepside Registered Member
    Feb 5, 2006
    46
    Huntsville AL
    sounds like a full time with lock outs...its just your linkage. Mine was doing the same thing, only it wouldnt go into low lock
  8. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    ok I think that Im gonna try to figure out my linkage and how do i work on that not sure about the 203 cant wait to get my 465 205 combo!!! in a one ton frame
  9. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Sometimes ignorant folks put lock outs on without moding the t-case in hopes of better fuel economy, less wear on tires etc etc. Any book I have read about it says this is BAD on the case. Good luck getting up in that linkage. IIRC- that linkage has no adjustment. It's solid rods isnt it? You ever grease or smear oil on your shifters under there? Dirt can make them bind up and hard to shift. I just flat out don't like 203s. You will like your 205- I promise.
  10. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    Yup I cant wait Ive had the 208 the dredded 203 and soon the 205. gonna be good. Gonna have to try to greese them solid shift link up and see what i can do.
  11. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    Put the tcase in neutral, make sure it's in neutral, undo the shifter linkages(back off the nuts on both sides). There is a hole in the side of the shifter & both levers, move the levers until you can put a drill bit (if I remember correct it's like 3/16")through the hole & both levers, then tighten the linkages to that spot.
    That re-sets the shifter linkages & the case to neutral.
    The case might not be in neutral when the shifter says it is, you have to make sure the case is in neutral, otherwise it will be wrong.
  12. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    This kinda makes sense but if there is no adjustment in the linkage what is he adjusting? I don't get the "then tighten the linkages to that spot." part???
  13. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    have you ever seen a 203 t-case? it has adjustable levers/linkages.
  14. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    It's been a few years but yea I swapped mine out for a 205. I just don't recall the linkages being threaded/ajustable. Thats why I was aksing for verification on my second post.
  15. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    yea teh 203 is adjustable, the shifter assembly looks like some one at nasa came up with to just complicate things, ditched mine for a twin stick. If you have lock out hubs and a full time case(no part time conversion) I assume you are driving around every day in 4high loc(front drive shaft spinning) because the differenital would just spin the front shaft if not in loc, kind of defeats the point but if you have it why not i guess. i know the haynes manual has a how to on adjust the linkage as stated before.
