Transfer Case Questions
Discussion in 'The Garage' started by RustBuket, Sep 28, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I recently purchased an 81' blazer that was all stock. Now, it has a rebuilt motor and edelbrock manifold, headers, dual exhaust, and emissions equip. removed. When I put in in 4lo I get a whine from the transfer case. I was just wondering if this is normal or not? I wanted to check the fluid level but was not sure how or what to oil to but back in if I did change it. I was looking @ the T-case the other day and there are too plugs on the back side. One up high and one at the bottom. I was wondering if these would be the drain/fill plugs? Also, what oil do you put in differentials? I am going to change those as well because I don't know what the last time the PO did that. Any help is appreciated! /forums/images/graemlins/ears.gif
    P.S. What type of T-case would I have? NP203?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    80 - 90 gear oil for the diff's
    You should have a NP205 in your 81, what fluid to use on it i have no idea all i know is a NP203 takes 30w motor oil.
  3. RustBuket
    Feb 21, 2003
    1,618
    How can i make sure I have an NP205 cause thats sweet if I do! Also, more input on drain/fill plugs + what type of oil to use would be appreciated. /forums/images/graemlins/thinking.gif
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I believe the same gear oil mentioned above for a 203 or a 205 is right. There was gear oil in the 203 I drained the other day /forums/images/graemlins/thumb.gif As for the diff this is a 203
    This is a 205
  5. RustBuket
    Feb 21, 2003
    1,618
    Ok thanks guys! I think I have an NP205 just lookin at the pics but I'll have to double check. Thanks for the tips.
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Look for a small round plate with 3 bolts on the rear of the case, also look for the tag on the passenger side front it will say NP205 or New Process 205.
  7. RustBuket
    Feb 21, 2003
    1,618
    I'll check as soon as there is light!
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Another easy way to tell is look at the shifter. If you have 2hi, 4hi, and 4lo, then you have a 205. If you have L LOC, L, H, H LOC then you have a 203.
  9. RustBuket
    Feb 21, 2003
    1,618
    Well its a 205 then! Is the 205 stronger than the 203?
  10. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Well, the 203 is chain driven and the 205 is gear driven. Both are very strong, but the 205 wins the contest.
  11. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    a lot of 1981 had the 350 tranny with a 208 tcase Is it a ALUMINUM CASE????
    if so then 208 it is
    what size head does the drain and fill plugs have on it 9/16 or
    1 1/8"???
  12. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    yep, if it's aluminum than it's a 208 and they have 2hi,4hi,N,4lo like the 205. Maybe you will get lucky and have a 241 late model case swapped in like mine does in my 85. /forums/images/graemlins/thumb.gif
