Transfer case seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tybee, Mar 31, 2002.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    How hard is it to replace a seal on the transfer case front driveshaft one and what does it involve, I think its a 208. Thanks, Troy
  2. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    You'll need common hand tools; and a large socket to remove the front output yoke. Take off the front driveshaft, drain the ATF, remove front output yoke, and then you will have access to the seal. Then you can R&R the seal, reinstall the yoke and driveshaft, refill with ATF, and you're done.
    Will
