Transfer Case Separation from Transmission
Discussion in 'The Garage' started by BigRed89, Apr 12, 2003.
  1. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    This may sound like a simple question for some, but I haven't been able to find any answers from my searches. I have an '89 Suburban with the TH400 trans and NP241 transfer case. I've already removed the engine, and I would like to know how I can remove the transmission from the transfer case. I know how to get the two out of the vehicle, but I don't know how to separate the transmission from the transfer case, and what problems I should look out for. Any assistance is appreciated!
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Being that you have a 241 case if it is like my 208 there should be 6 bolts (I think) that hold the tcase to the tranny. You unbolt those 6 bolts and it should slip off.
    you also need to disconnect the shifter linkage on the tcase. On my 208 it had a cotter pin that held the linkage on. Pop the linkage and pull the case.
