transfer case shifter boot?
Discussion in 'The Garage' started by goofy1, Apr 14, 2007.
  1. goofy1
    goofy1 1/2 ton status
    Feb 13, 2005
    I changed from the 208 to the 205 transfer case and the shifter boot will not work for the 205 shifter(shift pattern is too long).I looked at LMC and found a couple http://http://www.lmctruck.com/icatalog/cc/0051.asp . Wich one should I use or do you have other suggestions other than the rag wrapped around it for now?
    I also am using a 2-wheel drive cab that I just cut the floor for the 208 and not sure if the stock 205 boot would require modification:hack:
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    you should be able to make something work for cheap and look real nice if you pick up a universal boot at the hardware store. originally i had a 700r4/np208 and swapped in a 465/np205 - which is significantly shorter. granted, mine was 4wd to begin with, but the stock hole was sufficient in size, but you're right that you can't use the same boot/indicator box. i don't have an indicator now - i just know what gear it's in.
