Transfer Case Shifter Question
Discussion in 'The Garage' started by jim burke, Mar 9, 2005.
  1. jim burke
    jim burke Registered Member
    Jul 13, 2004
    37
    Somewhere
    The transfer case shifter on my '89 Blazer only moves between 2H and 4H (it won't go into neutral or 4L). The problem's definitely the shifter, not the transfer case. The linkage between the two is fine. Is there some "trick" to getting it to go into 4L? I've tried pushing down on the knob, pulling up on it, making sure the transmission is in low gear, neutral, park, etc., but no luck. I'm thinking maybe something is jammed up, but before I take the shifter apart I wanted to make sure I'm not just doing something wrong.
    TIA.
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Try it in gear rolling very slowly.....?
    Sometimes I have to do that with mine.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Truck in neutral and stopped. Pull back and to the right. If the shifter has been taken apart, the plastic "indicator" needs to ebe lined up before the shifter is put back on or it will stick and only allow you into 4hi. Takes about 5 mins and a phillips head to check, but if the indicator is not moving when you pull the lever, that could be it.
  4. jim burke
    Jul 13, 2004
    37
    Somewhere
    I'll try that (I was pulling straight back). The indicator seems to move okay when I shift between 2H and 4H.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, I have had times where you have to be in Neutral to get the truck into 4 low...
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Yeah, the basics first ;) Good call.
