Transfer case stabilzer bar?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Jan 24, 2001.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Yesterday I noticed a 1/2" rod bolted to the passenger side of the transfer case. It runs forward on 45 degree angle and looks like it bolts to the engine block. A buddy said it was a TC stabilizer bar, but wasn't sure why it's there. Is it important?
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    I know what bar you're talking about, and I've been told that without it you can crack your trans housing where it connects to your transfer case.
    MY K-5 DOESN'T LEAK... IT JUST MARKS ITS TERRITORY.
  3. Can Can
    15,552
    136
    Yeah, I figured as much.........It kinda looks like a brace to keep everything from torquing out.......
  4. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Yes it is important. As mentioned chevy had problems with trans cases cracking...this along with somewhere in 78-79 adding an aluminum flywheel cover with 2 additional braces running to the motor mount pads took care of the problem....i have both set-ups on my 79...when i swapped in the NP205 i had to cut the bar down so it would fit. As i recall 69 to 72 K5's had an additional t-case mount on the right frame rail to add stability...something they dropped with the advent of the square nose in 73.
    Azblazer
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  5. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I'm not sure if this is the same brace you're talking about, but on my '73 I have a brace on my NP205. It is on the passenger side and attaches to the right frame rail. Thought it was cool, Haven't seen one on newer K5s. Maybe it's a hold over.
  6. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    YES it they are very important.... I didnt realize my truck didnt have them when I bought it... And low and behold my transfercase slipt from the tranny ripping out my drive shaft and spewing fluid every where good thing i was only a mile from home. So now I am on the hunt for those bars.. Anyone have any laying around???
    BlazerBoy
    http://generalblueballs.coloradok5.com
  7. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    With the "old style" tranfer cases, 203, 205 it was alot of wieght on the back of the tranny. When you hit a big old bump(not nesasarly off roading,) the chevy 350 trans cases would snap around the bellhousing. Chevy called them a "strut." I replaced many 350 cases at the dealer under warranty. No I could never afford a new K5, I was just a mechanic!
