transfer case swap
Discussion in 'The Garage' started by bigred85, Feb 13, 2005.
  1. bigred85
    bigred85 Registered Member
    Jul 12, 2004
    61
    Dallas, TX
    What is involved with swapping in a 205 for my 208?? She's leakin' pretty bad, so I might as well upgrade. I have a 700r4, and I plan on replacing it with a th400 as soon as it craps out.
    Any help is appreciated.
    Thanks,
    Nick
  2. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    need shaft change and then you will have pan clearence issues. or you can get spacer and run the combo you have. eatherway drive shaft length is problem.
    i would save money and do swap all at same time and make sure 205 is 32 spline to mach the 400 and it has 6 bolt adaptor on case for 400 also. then do drive shafts 1 time.
    there has been lots of talk on here about 700 and 205 combos. do a serch in the garage.
