transfer case swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Jul 19, 2001.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I want to switch out my NP208 in my 86 Blazer to a NP241 so I can put a slip yoke eliminator on it. has anyone done this and how difficult?
    86 Blazer 4" lift 35" MTRs locked front, still 1/2 ton axles
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If I am not mistaking on this, I believe it is a bolt in swap.
    <font color=blue>Wayne<font color=blue>
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    You will have to find a 241 that came with a mechanical speedo cable, most of the later 241s came with electronic speedos, which will not work with your 86 truck. As long as you can find one with a mechanical speedo you should be able to bolt in...of course you are probably already planning on changing driveshafts, but that will need changing also...
  4. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    are you sure about the driveshaft part, is it to long or short? I know the output splines are the same, or were you just saying that because of the slip yoke kit?
    Thanks,
    Mike
    You call that dirty!?
  5. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    cool I'm planning on doing the same unless Jess and High Angle cones up with the SYE for the 208. Good luck
  6. 86K5TrailBlazer
    Apr 24, 2001
    436
    Orange,CA
  7. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    As far as I know the SYE uses a speedo gear.
