transfer case/trans question
Discussion in 'The Garage' started by kutter79, Jul 10, 2005.
  1. kutter79
    kutter79 Registered Member
    May 17, 2005
    48
    st. charles MO
    hey im pretty new to 4 wheel drive stuff. i kust got an 84 K5 w the 465 and 208. i found a leak in the tranny. im guessing its part of the transmission, because the fluid smeels like gear oil.i t is right between the two looks like it was cracked and somebody tried to braise it. didnt work too good. so im wondering if i can just get that piece. i will take a pic and try to post it so it will be easier to understand what im talking about. thanks for the help, sorry if sound like an idiot.
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I'm assuming you mean where the t-case bolts on to the back of the 465... If so then yes you can get just the t-case adapter.....go to a junkyard
  3. kutter79
    May 17, 2005
    48
    st. charles MO
    pics
    here is the pic. it is the part that bolts to the crossmember. so if anyone has one let me know. thanks again.
  4. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    that is the tcase to tranny adaptor. cast can be a pain to fix if not use to playing with it. might just be easyer to get a used one.
