Transfer Case
Discussion in 'The Garage' started by blazerboy5814, Apr 24, 2004.
  1. blazerboy5814
    blazerboy5814 Registered Member
    May 12, 2003
    10
    I have a 88 K5 blazer and my transfer case is stock. I recently have been having problems with my auto locking hubs. Well I noticed a little while before that my trans case was leaking well my question is would the auto locking hubs not be working do to the fact my trans case is low on oil? How can I check and fill my transfer case with oil?
    Please Help!
    /forums/images/graemlins/k5.gif /forums/images/graemlins/peace.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I don't think the transfercase has anything to do with the auto locking hubs, but I personally would change out the auto locking hubs for a set of Warns. /forums/images/graemlins/deal.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The tcase being locked into 4wd causes the front drivshaft to turn and turn the front axleshafts which causes the hubs to lock.
    Low oil in the tcase will not cause the front driveshaft not to turn so it has nothing to do with the hubs not working right.
    Low oil will cause you to burn up tcase bearings and stuff though.
    Harley
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, throw those auto hubs at someone you don't like.
    To check/fill t-case:
    Unbolt the fill plug(located on the back of the case, they're two big plugs, one on the bottom is the drain plug and the one towards the top is the fill plug)
    Fill with ATF until the fluid is level with the fill hole..
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    [/ QUOTE ] /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif
    every time I buy a truck with auto hubs, They are the FIRST thing i toss!!
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    90% of the time i've seen auto locking hubs fail was because of grit, grime and dirt. Still all things being equal, dump them and get some manuals. For nothing else then the peace of mind. They work when you need them too and when you don't want them engaged they aren't.
