transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by baldk5, Jun 3, 2001.
  1. baldk5
    baldk5 Registered Member
    Jun 3, 2001
    29
    nova scotia, Canada
    I got a 90k5 with 4" of lift (lift blocks in rear). I'm having problems with vibrations. The rear drive shft is running at about 17'. I found a np205 cheap, should I swap out my 241 for the 205 for the fixed yoke or does anyone know if i can get a fixed yoke for my 241?
  2. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    You can get a conversion for the 241. Try JB Conversions or Jesse the drivelineman. I think they kit is about $350 plus the driveshaft mods.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Have you dropped the transfer cae yet? If not, its easy. Look o nthe botls for the crossmember, and there are spacers on each one, but the yaren't doing anything. Move them from where they are to between the frame and the crossmember.
    90K5
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    If your rock crawling keep the 241 and convert it to fixed. If your just mudding, get the 205, however, your gonna have to rebuild your tranny, well, completely dis-assemble it to swap out the output shaft.
    But if you are going to extreme rock crawl, keep the 205 and get the doubler from ORD.
    Personally, I'd recommend the 241 fixed kit. The get you a CV driveshaft and forget about vibrations.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Are you sure that Highangle has a fixed kit for the 241? I was told by a partner of theirs that they use a longer slip shaft....
    Will be checking.
    Dave
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I have talked to Jesse at Highangle and he has told me that they have a Slip Yoke Eliminator kit, that requires that you take the T-case apart and put a shorter output shaft with a fixed yoke. So I would say yes, unless he was lying to me.
    How ever, JB COnversions sells them too.
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Cool. I want that one! I let you know what happens - should be ordering the parts this week and start soon after.
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, $hit, while your ordering, get me one 2.....
    Im still saving to get mine.
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I was quoted $300 for the longer slip - what does the eliminator run? We get the 10% discount from this site but maybe a higher discount for 2 since he the jig will be ready...?
    The shop I am working with is one of his testers also - will let you know this week.
    I think we are having this conversation over 2 posts - ha.
    Dave
  10. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Let me know what you decide to do with the NP 205. I may be interested in buying it if you don't use it.
    If you didn't built it yourself, how can you call it yours.......?
  11. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Something else to think about is that you have a VSS in your 90 model since your speedo is electronic. The 205 will have a mechanical output for a cable driven speedometer. You will either have to machine the 205 to accept a gear and VSS output or rewire your dash harness and put in a mechanical speedo. Either way can get fairly expensive.
    Russ
  12. baldk5
    Jun 3, 2001
    29
    nova scotia, Canada
    if you guys are gonna get 2, let me know, maybe they'll do better for 3.
  13. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I ordered my fixed kit yesterday - need to wait for measurements before I order the driveline. Call Jesse and ask for the CK5 discount. We are pointing business to him so hopefully we qualify for extra discounts :)
    Dave
    "Visualize Whirled Peas"
  14. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Painless Wiring, Jags That Run and several others sell adapters that will send the proper info to the computer and speedo. They run $80 to $100, depending on exactly which model you need for your application. Check out <A target="_blank" HREF=http://www.jagsthatrun.com/#VSS>http://www.jagsthatrun.com/#VSS</A>
    Does the '90 use a VSS that comes from the t-case? Earlier models (like the '88 I've been helping a friend strip) have a mechanical speedo that uses a rotating mirror and an LED to provide the VSS input.
    Either way, there are solutions. [​IMG]
  15. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I talked with both of those places and they did not have one for that application because it uses a 40 tooth reluctor? gear. I talked with some local speedo shops here in San diego also and they told me I would have to go with the VSS drive that mounts to the mechanical speedo output and then add the other box under the dash to convert the signal. All in all about $300. I went ahead and had an NP241 forty tooth gear machined to fit the output shaft on the 205 and then had a hole tapped in the housing on the 205 to accept the 241 VSS and everything works great.
    Russ
