Transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Mar 23, 2000.
    What's the easiest way to check the fluid level in the transfer case. Every once in a while I'll see a drip in the very edge, the blue bolt. I hope that doesn't sound weird, I don't know if there is even supposed to be a blue bolt there. I guess Its ATF.I just want to make shure eveythings OK.
    thanks,
    <font color=red>ABO</font color=red>
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    once IN a while
    <font color=purple>delta9blazer</font color=purple>
  2. Thanks!
    abo
  3. Steve88
    Steve88 1/2 ton status
    526
    Sunny Arizona !
    Another question on the same subject would be how often to change it and what do you use (regular ATF or multi-grade oil?) (BTW: I've got the NP208)
    <font color=red>Steve88</font color=red>[​IMG]
    88K5 Silverado
    thunderdog@metallica.com
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Chiltons say's to check it every 4 months or 6000 miles. And they SUGGEST using Dextron II.
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
