Transfer Case
Discussion in 'The Garage' started by OrangeCrushK10, Feb 3, 2003.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Which transfer case do I want? I really don't know much about transfer cases, but I know mine's trashed, heh. /forums/images/graemlins/rolleyes.gif
    So which one will I want to replace it with? /forums/images/graemlins/confused.gif
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    The good old cast iron NP205 is the strongest. What are you running now for tranny and t-case?? This will determine what you can run with you curent tranny.
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    Anything But an np208 they S@#$ A$$ I've fragged 3 in the last 2 months I'd say Np205 is your best bet or a np241 I heard that there tougher than a Np208 /forums/images/graemlins/truck.gif
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I would go with a 205. they are tough! do you know what you have now? cast iron or aluminum case?
  5. OrangeCrushK10
    Jan 25, 2003
    1,425
    I would assume a 205 since that's what the '80 blazer had. I doubt my K10 is any different.
    So my best bet is just to rebuild the t-case I have? Sounds good to me, hee hee. Thanks all! /forums/images/graemlins/thumb.gif
  6. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    Not always. If it's cast iron, ck to see if it has a fill plug and a drain plug. Only the 205 has the drain. If it has no drain, It's a 203. they used both.
  7. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    his profile says its an 80 K10-all 1980s should have a 205. But we all know how that goes.
  8. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    what is wrong w/ it? Did you run it dry or get water in it?
  9. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I know what should,but It's always good to make sure. A friend of mine, who's new to chevy trucks, has an 83 K10. He was trying to get parts for it and nothing would match up. His truck has a 203 T-Case, and a 12 bolt rear axel. It's always good to make sure!!
  10. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    [/ QUOTE ] very true
  11. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    What did you break,gears or the case.If you're breaking cases the 241 is alum and not much stronger.205s are bout the strongest. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  12. OrangeCrushK10
    Jan 25, 2003
    1,425
    It's almost impossible to shift at times, other times it's perfectly fine. The exterior looks okay, other than covered in dirt.
    Any thought at what could be causing that? I can only think it's maybe something internally in the t-case
  13. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    The 205 in my Bronco is sometimes hard to put in gear. I have learned that when it wont go in I would put it in first (manual) and move a forward a few inches and it would go. If you have an automatic make sure your in neutral only.
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    practice,
    if it is 205 you have to learn to shift.
    auto tranny?
  15. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    If its an auto; trans in N, w/ the truck rolling, now shift, don't stop at N on the x-fer case. You can also mod the rails for 2 LO. Depdog did this and said his also shifts easier now. I was going to do the same but my 205 truck is parked right now.
  16. OrangeCrushK10
    Jan 25, 2003
    1,425
    a-u-t-o-m-a-t-i-c???!!! What the hell is that?! /forums/images/graemlins/rotfl.gif Oh, you mean that tranny in my LUV!
    Nah this is a 4-speed. Hee hee, and from what it seems, I scared it straight with all this talk of replacing it. It's worked the best the last two days than it ever has since I bought it a month ago. /forums/images/graemlins/rolleyes.gif
    Really, I'm starting to think it's all that GM 10-bolt up front. All I've changed in the last couple days is new tires. Maybe the old tires were uneven and warping my front diff a bit, therefore causing the t-case to hate me? I was having a bad time with the lockers too with the old tires, and now they're also working great.
    I dunno. I need a d60 up front, though. I'm thinking that's my next big buy... well, after an acoustic bass guitar I've had my eye on for a while, hee hee.
    Then a d60! I'm tired of that GM 10-bolt and having to tear the hub apart every couple weeks to tighten everything back up since it all has the bad habit of wiggling lose since it's been damaged. /forums/images/graemlins/angryfire.gif
    Ah-well, what do I expect from a truck I got for $600? Hee hee.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    lockers and a 205 can easily load up the gears,
    apply pressure to the shifter and bump the clutch a few times in gear
    it is a feel thing you will learn
  18. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    most deff its a 205 then.
