transfer cases for the 700r4
Discussion in 'The Garage' started by dodgedude99, May 22, 2004.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    what else besides the cracked np 241 i have on my '88 now, besides the 208 of course.
    would the 205 work?
  2. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    YOu need a shorter output shaft from a th350(I think) along with the correct adapter. How did you crack your 241? Drop it on the rocks? I personally don't see the need for a 205 (unless it came factory) over a 241 unless the extra strength is actually required and it will be slammed on rocks periodicly. The 241 is an easier T-case to live with stock IMHO because it has a much lower gear range, is lighter, and shifts good. Take care of the slip yoke and make a good skidplate and you have a case that can handle some pretty serious torment....
  3. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    no it was my stupid mistake for not checking the truck out better before i bought it, but i did only pay $700 for it.
    i did see the silicone or the crack with all the grease and grime that was on it.
    it wasnt til after i sprayed it down with castrol superclean and pressure washed it that i seen the silicone, and the small lake under it the next morning.
    how does the 208 compare to the 241 if i cant find another 241 at the junkyard?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 241 has a lower low range than the 208 (2.72 vs. 2.61) the case on the 241 is alittle stronger than the 208, on the 241 there is a true SYE kit for it. i would try to find a 241, but a 208 will get you down the trail /forums/images/graemlins/waytogo.gif
  5. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Look for a 241, it's a better case. It's as simple as that. /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If your 88 has a 241 in it somebody already swapped it in. 89 was the first year for the 241 and the only year they had a speedo gear. In 90 and up they used a electronic speedo. But if you find a 90 or 91 to swap in then all you need to do is swap the speedo parts. The output shafts are the same weather it has a gear or toner ring on it.
    To swap a 205 in you will need to tear the trans down to replace the output shaft. A 208 from a 700r4 will bolt right on too.
  7. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    according to the specifications list on the homepage '88 was the first year for the 241.
    thats the only thing that sucks about buying a used vehicle.
    you dont know exactly what is original, or what was upgraded.
    the rear axle im taking out is a 12 bolt also.
    thr tranny shifts hard like it has a shift kit in it.
    and the motor seems to run pretty damn good for having 135k miles on it.
