transfer cases
Discussion in 'The Garage' started by hammermachine, Sep 18, 2006.
  1. hammermachine
    hammermachine 1/2 ton status
    Aug 23, 2005
    2,450
    6
    Still in New Jersey!
    :bow: How hard is it to remove and install a new NP208. For a layman with limited tools. Has anybody done it before. My current 208 doesn't shift. When you shift the shifter there is no resistance it does not feel like it's shifting into 4hi, 4lo, or anything. Anythoughts.
  2. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Crawl under the truck and check the shift linkage. If one of the little cotter pins rusted and broke there is a good chance that it is just disconnected.
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, check the linkage first.
    On a scale of 1-10 in difficulty,
    1. being changing a light bulb
    10. being auto trans rebuild
    I'd give it a 3.5
  4. hammermachine
    Aug 23, 2005
    2,450
    6
    Thanks that's good to know, I'll check the linkage.
  5. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Its pretty easy.
    1 Drain the case
    2 Remove the driveshafts
    3 Disconnect the shift linkage
    4 Remove the 6 bolts holding the T-case onto the adapter
    I've swapped a 208 to a 241 by myself. It can be done, the cases aren't that heavy, but it would have been nice to have an extra set of hands to lift the transfer case into position.
  6. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    You drain the fluid???:confused: :screwy:
    :D
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    either you drain it or it'll drain itself some. your choice:p: :haha:
  8. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    You need a 5/8" wrench for the front shaft. probably a 1/2" wrench for the rear driveshaft to pinion yoke. A 9/16" wrench for the bolts that connect the tcase to the adapter. And a 1-3/16 wrench or big cresent for the drain plug. A pair of pliers for the shift linkage cotter pin.
    You'll need RTV or gasket material when you put the new case in.
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    You laugh.....but I learned the hard way. ATF baths are not fun....
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I don't drain mine when i pull it either, but then again i have a SYE kit on mine. :D
  11. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Yeah, I was taking my 208 off to install my 241 with SYE at the time.... :D
