transfer id
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ed1507, Mar 21, 2003.
  1. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    help the case is stamped with gm34288 what modle is any one know ed. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Does it have an aluminum case or cast iron? If it's AL it probably either a 208 or 241. The 208 was used from 81-88(?) and was replaced by the 241 in 89(?). If it's cast iron it is probably either a 205 or 203. The 203 is most noticeable because it has a seperate "range box" mounted to it and is chain driven. The 205 is also cast iron and is gear driven, the easiest way to identify it is the small cover on the back with 3 bolts. There is usually a tag on them that will indicate what model it is.
    Try doing a search and you will find lots more info and maybe pics.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah youre gonna have to tell us what it looks like and what case is made of and etc.
  4. ed1507
    Jan 25, 2003
    70
    indiana
    [image]c/1[/image] its cast iron all right
