transfer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ed1507, Mar 18, 2003.
  1. ed1507
    ed1507 Registered Member
    Jan 25, 2003
    70
    indiana
    hello heres a question i have a 85 k5 with a 700r trans and i beleve a np208 transfer wich i think went bad can i put a np205 in its place and what would i need to do it thanks ed. /forums/images/graemlins/usaflag.gif
  2. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    yes you can, but i think the adapter is like several hundred dollars /forums/images/graemlins/shocked.gif.. maybe try these guys /forums/images/graemlins/confused.gif www.advanceadapters.com
    or you could find a 2wd 700r4 and use a divorced 205 /forums/images/graemlins/thumb.gif
  3. sammyt
    sammyt Registered Member
    Jan 19, 2003
    10
    Texas
    You should be able to bolt it up but if for some reason you cant an adapter for it would be like $700. But like i said i dont think a 205 should just bolt up but stranger things have happened>
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    You have 2 choices:
    1)Either buy the shorter output shaft for the 700r4 and use a 205 and adapter off of a th350 (I think the shaft is about $160, but the trans has to be disassembled to install it)
    2)Buy an adapter for about $60 and then just bolt the 205 and adapter from a th350 right in place.
    Check out this link, it shows you where to get the adapter.
    http://coloradok5.com/forums/showflat.php?Cat=&Board=blazer4x4&Number=611172&PHPSESSID=&fpart=1#Post611172
    The main thing is, you need to find a 205 with the adapter that was behind a th350 because the th350 is a 27 spline like the 700r4. Otherwise youll have to swap input gears in the 205.
    You will also need a 205 shifter, new driveshafts and a new crossmember.
